Time Before: 0.01789 seconds
Time After: 0.02309 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02318 seconds
Time After: 0.02391 seconds
Time Taken: 0.00072 seconds
Time Before: 0.02436 seconds
Time After: 0.02454 seconds
Time Before: 0.02524 seconds
Time After: 0.02771 seconds
Time Taken: 0.00246 seconds
Time Before: 0.02459 seconds
Time After: 0.03190 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04091 seconds
Time After: 0.04133 seconds
Time Before: 0.04402 seconds
Time After: 0.04529 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04016 seconds
Time After: 0.04556 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.820 KB
Time Before: 0.06401 seconds
Time After: 0.06431 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08717 seconds
Time After: 0.08846 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.09875 seconds
Time After: 0.09894 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10130 seconds
Time After: 0.10274 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789140314, location = '/forums/private.php?do=newpm&explain=1&u=119709', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.12033 seconds
Time After: 0.12064 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
