Time Before: 0.00217 seconds
Time After: 0.00276 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00286 seconds
Time After: 0.00331 seconds
Time Before: 0.00352 seconds
Time After: 0.00364 seconds
Time Before: 0.00447 seconds
Time After: 0.00717 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00371 seconds
Time After: 0.01306 seconds
Time Taken: 0.00935 seconds
Time Before: 0.01551 seconds
Time After: 0.01587 seconds
Time Before: 0.01831 seconds
Time After: 0.01953 seconds
Time Before: 0.01477 seconds
Time After: 0.01979 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02644 seconds
Time After: 0.02664 seconds
Time Before: 0.02913 seconds
Time After: 0.03037 seconds
End call of global.php: 0.032073020935059
Time Before: 0.03326 seconds
Time After: 0.03347 seconds
Time Before: 0.03566 seconds
Time After: 0.03717 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119711', badlocation = 1
Time Before: 0.05408 seconds
Time After: 0.05435 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.052917957305908 seconds with 9 queries, spending 0.0082736015319824 doing MySQL queries and 0.044644355773926 doing PHP things.
