Time Before: 0.00140 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00250 seconds
Time Before: 0.00278 seconds
Time After: 0.00293 seconds
Time Before: 0.00379 seconds
Time After: 0.00658 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00301 seconds
Time After: 0.01130 seconds
Time Taken: 0.00829 seconds
Time Before: 0.01353 seconds
Time After: 0.01389 seconds
Time Before: 0.01635 seconds
Time After: 0.01757 seconds
Time Before: 0.01290 seconds
Time After: 0.01776 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02343 seconds
Time After: 0.02358 seconds
Time Before: 0.02589 seconds
Time After: 0.02710 seconds
End call of global.php: 0.02878999710083
Time Before: 0.02985 seconds
Time After: 0.02998 seconds
Time Before: 0.03224 seconds
Time After: 0.03382 seconds
Time Taken: 0.00158 seconds
SET lastactivity = 1789106285, location = '/forums/private.php?do=newpm&explain=1&u=11972'
Time Before: 0.04781 seconds
Time After: 0.04816 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046857833862305 seconds with 9 queries, spending 0.0084707736968994 doing MySQL queries and 0.038387060165405 doing PHP things.
