Time Before: 0.00809 seconds
Time After: 0.01033 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01041 seconds
Time After: 0.01088 seconds
Time Before: 0.01117 seconds
Time After: 0.01134 seconds
Time Before: 0.01213 seconds
Time After: 0.01433 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01139 seconds
Time After: 0.01942 seconds
Time Taken: 0.00802 seconds
Time Before: 0.02283 seconds
Time After: 0.02322 seconds
Time Before: 0.02555 seconds
Time After: 0.02676 seconds
Time Before: 0.02213 seconds
Time After: 0.02695 seconds
Time Taken: 0.00482 seconds
Time Before: 0.04145 seconds
Time After: 0.04159 seconds
Time Before: 0.04659 seconds
Time After: 0.04798 seconds
Time Taken: 0.00140 seconds
End call of global.php: 0.049746036529541
Time Before: 0.05255 seconds
Time After: 0.05270 seconds
Time Before: 0.05487 seconds
Time After: 0.05633 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119726'
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.07237 seconds
Time After: 0.07272 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.071249008178711 seconds with 9 queries, spending 0.0079350471496582 doing MySQL queries and 0.063313961029053 doing PHP things.
