Time Before: 0.02425 seconds
Time After: 0.03360 seconds
Time Taken: 0.00935 seconds
Time Before: 0.03370 seconds
Time After: 0.03414 seconds
Time Before: 0.03450 seconds
Time After: 0.03467 seconds
Time Before: 0.03559 seconds
Time After: 0.03860 seconds
Time Taken: 0.00301 seconds
Time Before: 0.03473 seconds
Time After: 0.04304 seconds
Time Taken: 0.00831 seconds
Time Before: 0.05344 seconds
Time After: 0.05385 seconds
Time Before: 0.05636 seconds
Time After: 0.05756 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05272 seconds
Time After: 0.05778 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.719 KB
Time Before: 0.09160 seconds
Time After: 0.09177 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11533 seconds
Time After: 0.11658 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11907005310059
Time Before: 0.12510 seconds
Time After: 0.12530 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12808 seconds
Time After: 0.12959 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=11974', badlocation = 1
Time Before: 0.15010 seconds
Time After: 0.15051 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.14900493621826 seconds with 9 queries, spending 0.0087649822235107 doing MySQL queries and 0.14023995399475 doing PHP things.
