Time Before: 0.00266 seconds
Time After: 0.00365 seconds
Time Taken: 0.00098 seconds
Time Before: 0.00377 seconds
Time After: 0.00426 seconds
Time Before: 0.00450 seconds
Time After: 0.00465 seconds
Time Before: 0.00562 seconds
Time After: 0.00789 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00473 seconds
Time After: 0.01353 seconds
Time Taken: 0.00880 seconds
Time Before: 0.01535 seconds
Time After: 0.01575 seconds
Time Before: 0.01713 seconds
Time After: 0.01832 seconds
Time Before: 0.01479 seconds
Time After: 0.01849 seconds
Time Taken: 0.00370 seconds
Time Before: 0.02397 seconds
Time After: 0.02413 seconds
Time Before: 0.02646 seconds
Time After: 0.02776 seconds
Time Before: 0.03068 seconds
Time After: 0.03087 seconds
Time Before: 0.03292 seconds
Time After: 0.03434 seconds
UPDATE session SET lastactivity = 1789147544, location = '/forums/private.php?do=newpm&explain=1&u=119741' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05017 seconds
Time After: 0.05044 seconds
