Time Before: 0.01117 seconds
Time After: 0.01427 seconds
Time Taken: 0.00309 seconds
Time Before: 0.01437 seconds
Time After: 0.01479 seconds
Time Before: 0.01512 seconds
Time After: 0.01526 seconds
Time Before: 0.01621 seconds
Time After: 0.01810 seconds
Time Taken: 0.00189 seconds
Time Before: 0.01533 seconds
Time After: 0.02201 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02670 seconds
Time After: 0.02714 seconds
Time Before: 0.02970 seconds
Time After: 0.03094 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02600 seconds
Time After: 0.03117 seconds
Time Taken: 0.00517 seconds
Memory After: 2,261.703 KB
Time Before: 0.05733 seconds
Time After: 0.05746 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06955 seconds
Time After: 0.07085 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07828 seconds
Time After: 0.07842 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08094 seconds
Time After: 0.08245 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119764' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10041 seconds
Time After: 0.10524 seconds
Time Taken: 0.00483 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
