Time Before: 0.02305 seconds
Time After: 0.03204 seconds
Time Taken: 0.00899 seconds
Time Before: 0.03215 seconds
Time After: 0.03263 seconds
Time Before: 0.03288 seconds
Time After: 0.03301 seconds
Time Before: 0.03389 seconds
Time After: 0.03699 seconds
Time Taken: 0.00310 seconds
Time Before: 0.03307 seconds
Time After: 0.04100 seconds
Time Taken: 0.00793 seconds
Time Before: 0.05128 seconds
Time After: 0.05169 seconds
Time Before: 0.05485 seconds
Time After: 0.05610 seconds
Time Before: 0.05056 seconds
Time After: 0.05636 seconds
Time Taken: 0.00580 seconds
Time Before: 0.09314 seconds
Time After: 0.09326 seconds
Time Before: 1.35758 seconds
Time After: 1.35922 seconds
Time Taken: 0.00164 seconds
End call of global.php: 1.3612761497498
Time Before: 1.36937 seconds
Time After: 1.36952 seconds
Time Before: 1.37190 seconds
Time After: 1.37337 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119773', badlocation = 1
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 1.39276 seconds
Time After: 1.39306 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 1.3917479515076 seconds with 9 queries, spending 0.0090582370758057 doing MySQL queries and 1.3826897144318 doing PHP things.
