Time Before: 0.01090 seconds
Time After: 0.01410 seconds
Time Taken: 0.00320 seconds
Time Before: 0.01418 seconds
Time After: 0.01461 seconds
Time Before: 0.01483 seconds
Time After: 0.01500 seconds
Time Before: 0.01571 seconds
Time After: 0.01832 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01507 seconds
Time After: 0.02302 seconds
Time Taken: 0.00795 seconds
Time Before: 0.03087 seconds
Time After: 0.03128 seconds
Time Before: 0.03389 seconds
Time After: 0.03511 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03012 seconds
Time After: 0.03537 seconds
Time Taken: 0.00525 seconds
Memory After: 2,261.703 KB
Time Before: 0.04875 seconds
Time After: 0.04897 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05789 seconds
Time After: 0.05935 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.06608 seconds
Time After: 0.06625 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06886 seconds
Time After: 0.07035 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119814', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.08723 seconds
Time After: 0.08755 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
