Time Before: 0.01113 seconds
Time After: 0.01643 seconds
Time Taken: 0.00530 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01650 seconds
Time After: 0.01689 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01712 seconds
Time After: 0.01728 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01802 seconds
Time After: 0.02053 seconds
Time Taken: 0.00251 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01733 seconds
Time After: 0.02432 seconds
Time Taken: 0.00699 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03245 seconds
Time After: 0.03283 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03541 seconds
Time After: 0.03661 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03184 seconds
Time After: 0.03683 seconds
Time Taken: 0.00498 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.06213 seconds
Time After: 0.06228 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.10283 seconds
Time After: 0.10416 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.10651302337646
Time Before: 0.12578 seconds
Time After: 0.12595 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.13134 seconds
Time After: 0.13291 seconds
Time Taken: 0.00157 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772875781, location = '/forums/private.php?do=newpm&explain=1&u=119816'
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.15554 seconds
Time After: 0.15581 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
Page generated in 0.15450716018677 seconds with 9 queries, spending 0.0081043243408203 doing MySQL queries and 0.14640283584595 doing PHP things.
