Time Before: 0.01079 seconds
Time After: 0.01463 seconds
Time Taken: 0.00383 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.01473 seconds
Time After: 0.01527 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.01557 seconds
Time After: 0.01569 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.01648 seconds
Time After: 0.01891 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.01577 seconds
Time After: 0.02357 seconds
Time Taken: 0.00781 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.02838 seconds
Time After: 0.02886 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.03118 seconds
Time After: 0.03247 seconds
Memory Before: 2,770.063 KB
Memory After: 2,769.922 KB
Time Before: 0.02757 seconds
Time After: 0.03275 seconds
Time Taken: 0.00519 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.281 KB
Memory Used: 133.125 KB
Time Before: 0.06030 seconds
Time After: 0.06045 seconds
Memory Before: 3,436.383 KB
Memory After: 3,436.898 KB
Time Before: 0.06955 seconds
Time After: 0.07085 seconds
Memory Before: 3,524.180 KB
Memory After: 3,524.773 KB
Time Before: 0.07728 seconds
Time After: 0.07745 seconds
Memory Before: 4,162.102 KB
Memory After: 4,162.531 KB
Time Before: 0.08046 seconds
Time After: 0.08197 seconds
Time Taken: 0.00151 seconds
Memory Before: 4,443.641 KB
Memory After: 4,445.328 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=119819', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.10009 seconds
Time After: 0.10040 seconds
Memory Before: 4,922.000 KB
Memory After: 4,922.227 KB
