Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00242 seconds
Time Before: 0.00262 seconds
Time After: 0.00274 seconds
Time Before: 0.00350 seconds
Time After: 0.00556 seconds
Time Taken: 0.00205 seconds
Time Before: 0.00279 seconds
Time After: 0.00912 seconds
Time Taken: 0.00634 seconds
Time Before: 0.01107 seconds
Time After: 0.01149 seconds
Time Before: 0.01496 seconds
Time After: 0.01617 seconds
Time Before: 0.01039 seconds
Time After: 0.01643 seconds
Time Taken: 0.00605 seconds
Time Before: 0.02424 seconds
Time After: 0.02439 seconds
Time Before: 0.85354 seconds
Time After: 0.85499 seconds
Time Before: 0.86193 seconds
Time After: 0.86206 seconds
Time Before: 0.86450 seconds
Time After: 0.86593 seconds
UPDATE session SET lastactivity = 1788961458, location = '/forums/private.php?do=newpm&explain=1&u=119821', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.88497 seconds
Time After: 0.88531 seconds
