Time Before: 0.00586 seconds
Time After: 0.00804 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00814 seconds
Time After: 0.00864 seconds
Time Before: 0.00894 seconds
Time After: 0.00909 seconds
Time Before: 0.00995 seconds
Time After: 0.01273 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00918 seconds
Time After: 0.01673 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02035 seconds
Time After: 0.02091 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02383 seconds
Time After: 0.02510 seconds
Time Before: 0.01961 seconds
Time After: 0.02527 seconds
Time Taken: 0.00565 seconds
Time Before: 0.03515 seconds
Time After: 0.03563 seconds
Time Before: 0.04115 seconds
Time After: 0.04239 seconds
End call of global.php: 0.044461011886597
Time Before: 0.04845 seconds
Time After: 0.04874 seconds
Time Before: 0.05082 seconds
Time After: 0.05226 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=119825', badlocation = 1
Time Before: 0.06723 seconds
Time After: 0.06752 seconds
Page generated in 0.065932989120483 seconds with 9 queries, spending 0.0089893341064453 doing MySQL queries and 0.056943655014038 doing PHP things.
