Time Before: 0.01297 seconds
Time After: 0.01630 seconds
Time Taken: 0.00334 seconds
Time Before: 0.01640 seconds
Time After: 0.01680 seconds
Time Before: 0.01702 seconds
Time After: 0.01716 seconds
Time Before: 0.01801 seconds
Time After: 0.02072 seconds
Time Taken: 0.00271 seconds
Time Before: 0.01728 seconds
Time After: 0.02470 seconds
Time Taken: 0.00742 seconds
Time Before: 0.02981 seconds
Time After: 0.03021 seconds
Time Before: 0.03260 seconds
Time After: 0.03380 seconds
Time Before: 0.02911 seconds
Time After: 0.03405 seconds
Time Taken: 0.00494 seconds
Time Before: 0.07090 seconds
Time After: 0.07104 seconds
Time Before: 0.29263 seconds
Time After: 0.29413 seconds
Time Taken: 0.00150 seconds
Time Before: 0.30180 seconds
Time After: 0.30198 seconds
Time Before: 0.30482 seconds
Time After: 0.30631 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11985', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.32565 seconds
Time After: 0.32591 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
