Time Before: 0.03002 seconds
Time After: 0.04144 seconds
Time Taken: 0.01142 seconds
Time Before: 0.04157 seconds
Time After: 0.04215 seconds
Time Taken: 0.00059 seconds
Time Before: 0.04248 seconds
Time After: 0.04264 seconds
Time Before: 0.04336 seconds
Time After: 0.04702 seconds
Time Taken: 0.00366 seconds
Time Before: 0.04271 seconds
Time After: 0.05266 seconds
Time Taken: 0.00996 seconds
Time Before: 0.06689 seconds
Time After: 0.06732 seconds
Time Before: 0.07028 seconds
Time After: 0.07150 seconds
Time Before: 0.06600 seconds
Time After: 0.07174 seconds
Time Taken: 0.00574 seconds
Time Before: 0.10751 seconds
Time After: 0.10769 seconds
Time Before: 0.12640 seconds
Time After: 0.12761 seconds
Time Before: 0.13682 seconds
Time After: 0.13699 seconds
Time Before: 0.13969 seconds
Time After: 0.14117 seconds
UPDATE session SET lastactivity = 1776659334, location = '/forums/private.php?do=newpm&explain=1&u=11992', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.16189 seconds
Time After: 0.16452 seconds
Time Taken: 0.00264 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
