Time Before: 0.00486 seconds
Time After: 0.00640 seconds
Time Taken: 0.00154 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00653 seconds
Time After: 0.00698 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00723 seconds
Time After: 0.00735 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00824 seconds
Time After: 0.01094 seconds
Time Taken: 0.00271 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00743 seconds
Time After: 0.01591 seconds
Time Taken: 0.00847 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01922 seconds
Time After: 0.01969 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02294 seconds
Time After: 0.02419 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01843 seconds
Time After: 0.02446 seconds
Time Taken: 0.00603 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.03358 seconds
Time After: 0.03375 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.04440 seconds
Time After: 0.04570 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.05843 seconds
Time After: 0.05862 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.06139 seconds
Time After: 0.06292 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1769126951, location = '/forums/private.php?do=newpm&explain=1&u=119934', badlocation = 1 WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.07963 seconds
Time After: 0.07996 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
