Time Before: 0.03018 seconds
Time After: 0.03513 seconds
Time Taken: 0.00495 seconds
Time Before: 0.03522 seconds
Time After: 0.03562 seconds
Time Before: 0.03584 seconds
Time After: 0.03598 seconds
Time Before: 0.03679 seconds
Time After: 0.03903 seconds
Time Taken: 0.00224 seconds
Time Before: 0.03605 seconds
Time After: 0.04386 seconds
Time Taken: 0.00781 seconds
Time Before: 0.05164 seconds
Time After: 0.05202 seconds
Time Before: 0.05415 seconds
Time After: 0.05534 seconds
Time Before: 0.05095 seconds
Time After: 0.05558 seconds
Time Taken: 0.00463 seconds
Time Before: 0.09793 seconds
Time After: 0.09807 seconds
Time Before: 0.12097 seconds
Time After: 0.12261 seconds
Time Taken: 0.00164 seconds
Time Before: 0.13742 seconds
Time After: 0.13769 seconds
Time Before: 0.14037 seconds
Time After: 0.14189 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1785414610, location = '/forums/private.php?do=newpm&explain=1&u=120020' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.16590 seconds
Time After: 0.16619 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
