Time Before: 0.02645 seconds
Time After: 0.03150 seconds
Time Taken: 0.00505 seconds
Time Before: 0.03160 seconds
Time After: 0.03206 seconds
Time Before: 0.03237 seconds
Time After: 0.03253 seconds
Time Before: 0.03341 seconds
Time After: 0.03576 seconds
Time Taken: 0.00235 seconds
Time Before: 0.03261 seconds
Time After: 0.04128 seconds
Time Taken: 0.00867 seconds
Time Before: 0.05036 seconds
Time After: 0.05075 seconds
Time Before: 0.05348 seconds
Time After: 0.05554 seconds
Time Taken: 0.00206 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04968 seconds
Time After: 0.05578 seconds
Time Taken: 0.00609 seconds
Memory After: 2,261.703 KB
Time Before: 0.09192 seconds
Time After: 0.09217 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11289 seconds
Time After: 0.11418 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12326 seconds
Time After: 0.12345 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12620 seconds
Time After: 0.12776 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120041' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14839 seconds
Time After: 0.14865 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
