Time Before: 0.00131 seconds
Time After: 0.00175 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00182 seconds
Time After: 0.00225 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00250 seconds
Time After: 0.00263 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00342 seconds
Time After: 0.00580 seconds
Time Taken: 0.00237 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00268 seconds
Time After: 0.00980 seconds
Time Taken: 0.00711 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.195 KB
Time Before: 0.01202 seconds
Time After: 0.01247 seconds
Memory Before: 2,758.008 KB
Memory After: 2,758.625 KB
Time Before: 0.01472 seconds
Time After: 0.01602 seconds
Memory Before: 2,770.063 KB
Memory After: 2,769.922 KB
Time Before: 0.01141 seconds
Time After: 0.01626 seconds
Time Taken: 0.00485 seconds
Memory Before: 2,750.156 KB
Memory After: 2,883.281 KB
Memory Used: 133.125 KB
Time Before: 0.02146 seconds
Time After: 0.02160 seconds
Memory Before: 3,436.383 KB
Memory After: 3,436.898 KB
Time Before: 0.02347 seconds
Time After: 0.02472 seconds
Memory Before: 3,524.180 KB
Memory After: 3,524.773 KB
Time Before: 0.02768 seconds
Time After: 0.02784 seconds
Memory Before: 4,162.102 KB
Memory After: 4,162.531 KB
Time Before: 0.03005 seconds
Time After: 0.03152 seconds
Memory Before: 4,443.641 KB
Memory After: 4,445.328 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120046' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04629 seconds
Time After: 0.04657 seconds
Memory Before: 4,921.742 KB
Memory After: 4,921.961 KB
