Time Before: 0.00250 seconds
Time After: 0.00308 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00316 seconds
Time After: 0.00369 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00394 seconds
Time After: 0.00416 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00497 seconds
Time After: 0.00804 seconds
Time Taken: 0.00307 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00426 seconds
Time After: 0.01292 seconds
Time Taken: 0.00866 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01496 seconds
Time After: 0.01538 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01769 seconds
Time After: 0.01897 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01427 seconds
Time After: 0.01916 seconds
Time Taken: 0.00489 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02554 seconds
Time After: 0.02582 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03297 seconds
Time After: 0.03434 seconds
Time Taken: 0.00137 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04496 seconds
Time After: 0.04528 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04796 seconds
Time After: 0.04940 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120077' WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.06484 seconds
Time After: 0.06514 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
