Time Before: 0.01810 seconds
Time After: 0.02237 seconds
Time Taken: 0.00427 seconds
Time Before: 0.02245 seconds
Time After: 0.02286 seconds
Time Before: 0.02309 seconds
Time After: 0.02321 seconds
Time Before: 0.02405 seconds
Time After: 0.02610 seconds
Time Taken: 0.00205 seconds
Time Before: 0.02330 seconds
Time After: 0.03047 seconds
Time Taken: 0.00717 seconds
Time Before: 0.03670 seconds
Time After: 0.03712 seconds
Time Before: 0.04028 seconds
Time After: 0.04146 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03591 seconds
Time After: 0.04172 seconds
Time Taken: 0.00581 seconds
Time Before: 0.07117 seconds
Time After: 0.07131 seconds
Time Before: 0.08594 seconds
Time After: 0.08719 seconds
End call of global.php: 0.089501857757568
Time Before: 0.09376 seconds
Time After: 0.09390 seconds
Time Before: 0.09655 seconds
Time After: 0.09800 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120088'
Time Before: 0.11526 seconds
Time After: 0.11556 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.11421489715576 seconds with 9 queries, spending 0.0074601173400879 doing MySQL queries and 0.10675477981567 doing PHP things.
