Time Before: 0.01734 seconds
Time After: 0.02256 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02267 seconds
Time After: 0.02322 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02348 seconds
Time After: 0.02363 seconds
Time Before: 0.02449 seconds
Time After: 0.02724 seconds
Time Taken: 0.00275 seconds
Time Before: 0.02368 seconds
Time After: 0.03150 seconds
Time Taken: 0.00781 seconds
Time Before: 0.04090 seconds
Time After: 0.04131 seconds
Time Before: 0.04621 seconds
Time After: 0.04745 seconds
Time Before: 0.04017 seconds
Time After: 0.04773 seconds
Time Taken: 0.00755 seconds
Time Before: 0.10196 seconds
Time After: 0.10304 seconds
Time Taken: 0.00108 seconds
Time Before: 0.12427 seconds
Time After: 0.12568 seconds
Time Before: 0.14049 seconds
Time After: 0.14064 seconds
Time Before: 0.14363 seconds
Time After: 0.14523 seconds
Time Taken: 0.00160 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12013' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.16247 seconds
Time After: 0.16275 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
