Time Before: 0.00292 seconds
Time After: 0.00357 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00367 seconds
Time After: 0.00418 seconds
Time Before: 0.00446 seconds
Time After: 0.00464 seconds
Time Before: 0.00553 seconds
Time After: 0.00894 seconds
Time Taken: 0.00341 seconds
Time Before: 0.00472 seconds
Time After: 0.01238 seconds
Time Taken: 0.00766 seconds
Time Before: 0.01411 seconds
Time After: 0.01449 seconds
Time Before: 0.01710 seconds
Time After: 0.01838 seconds
Time Before: 0.01355 seconds
Time After: 0.01855 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02339 seconds
Time After: 0.02353 seconds
Time Before: 0.02550 seconds
Time After: 0.02673 seconds
End call of global.php: 0.028382062911987
Time Before: 0.02956 seconds
Time After: 0.02973 seconds
Time Before: 0.03169 seconds
Time After: 0.03315 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120132'
Time Before: 0.05155 seconds
Time After: 0.05187 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.050276041030884 seconds with 9 queries, spending 0.0090861320495605 doing MySQL queries and 0.041189908981323 doing PHP things.
