Time Before: 0.00170 seconds
Time After: 0.00217 seconds
Time Before: 0.00225 seconds
Time After: 0.00272 seconds
Time Before: 0.00304 seconds
Time After: 0.00320 seconds
Time Before: 0.00412 seconds
Time After: 0.00657 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00328 seconds
Time After: 0.01086 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01275 seconds
Time After: 0.01324 seconds
Time Before: 0.01581 seconds
Time After: 0.01705 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01209 seconds
Time After: 0.01723 seconds
Time Taken: 0.00514 seconds
Memory After: 2,261.703 KB
Time Before: 0.02329 seconds
Time After: 0.02398 seconds
Time Taken: 0.00069 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02664 seconds
Time After: 0.02799 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029774904251099
Time Before: 0.03112 seconds
Time After: 0.03143 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03338 seconds
Time After: 0.03482 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=120142', badlocation = 1
Time Before: 0.04718 seconds
Time After: 0.04758 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.046251058578491 seconds with 9 queries, spending 0.009009838104248 doing MySQL queries and 0.037241220474243 doing PHP things.
