Time Before: 0.00157 seconds
Time After: 0.00268 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00275 seconds
Time After: 0.00417 seconds
Time Before: 0.00443 seconds
Time After: 0.00459 seconds
Time Before: 0.00554 seconds
Time After: 0.00866 seconds
Time Taken: 0.00312 seconds
Time Before: 0.00468 seconds
Time After: 0.01310 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01480 seconds
Time After: 0.01519 seconds
Time Before: 0.01766 seconds
Time After: 0.01895 seconds
Time Before: 0.01428 seconds
Time After: 0.01911 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02413 seconds
Time After: 0.02436 seconds
Time Before: 0.02607 seconds
Time After: 0.02735 seconds
Time Before: 0.03046 seconds
Time After: 0.03062 seconds
Time Before: 0.03261 seconds
Time After: 0.03403 seconds
UPDATE session SET lastactivity = 1789140066, location = '/forums/private.php?do=newpm&explain=1&u=120174' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04630 seconds
Time After: 0.04670 seconds
