Time Before: 0.01057 seconds
Time After: 0.01637 seconds
Time Taken: 0.00580 seconds
Time Before: 0.01647 seconds
Time After: 0.01693 seconds
Time Before: 0.01718 seconds
Time After: 0.01730 seconds
Time Before: 0.01810 seconds
Time After: 0.02053 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01735 seconds
Time After: 0.02528 seconds
Time Taken: 0.00793 seconds
Time Before: 0.03279 seconds
Time After: 0.03319 seconds
Time Before: 0.03565 seconds
Time After: 0.03687 seconds
Time Before: 0.03199 seconds
Time After: 0.03707 seconds
Time Taken: 0.00508 seconds
Memory After: 2,262.484 KB
Memory Used: 132.898 KB
Time Before: 0.04923 seconds
Time After: 0.04935 seconds
Memory Before: 2,816.055 KB
Memory After: 2,816.570 KB
Time Before: 0.06403 seconds
Time After: 0.06526 seconds
Memory Before: 2,904.250 KB
Memory After: 2,904.844 KB
End call of global.php: 0.06710410118103
Time Before: 0.07442 seconds
Time After: 0.07460 seconds
Memory Before: 3,541.008 KB
Memory After: 3,541.438 KB
Time Before: 0.07695 seconds
Time After: 0.07843 seconds
Memory Before: 3,822.586 KB
Memory After: 3,824.273 KB
SET lastactivity = 1783005015, location = '/forums/private.php?do=newpm&explain=1&u=120195'
Time Before: 0.09455 seconds
Time After: 0.09486 seconds
Memory Before: 4,289.055 KB
Memory After: 4,289.281 KB
Page generated in 0.093476057052612 seconds with 9 queries, spending 0.0079250335693359 doing MySQL queries and 0.085551023483276 doing PHP things.
