Time Before: 0.00873 seconds
Time After: 0.01261 seconds
Time Taken: 0.00388 seconds
Time Before: 0.01272 seconds
Time After: 0.01314 seconds
Time Before: 0.01339 seconds
Time After: 0.01354 seconds
Time Before: 0.01440 seconds
Time After: 0.01696 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01362 seconds
Time After: 0.02142 seconds
Time Taken: 0.00780 seconds
Time Before: 0.02680 seconds
Time After: 0.02724 seconds
Time Before: 0.02899 seconds
Time After: 0.03164 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02603 seconds
Time After: 0.03200 seconds
Time Taken: 0.00598 seconds
Time Before: 0.04551 seconds
Time After: 0.04566 seconds
Time Before: 0.07752 seconds
Time After: 0.07877 seconds
Time Before: 0.08644 seconds
Time After: 0.08660 seconds
Time Before: 0.08924 seconds
Time After: 0.09072 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120200' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.10963 seconds
Time After: 0.10988 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
