Time Before: 0.00482 seconds
Time After: 0.00600 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00609 seconds
Time After: 0.00662 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00689 seconds
Time After: 0.00701 seconds
Time Before: 0.00789 seconds
Time After: 0.01056 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00709 seconds
Time After: 0.01526 seconds
Time Taken: 0.00817 seconds
Time Before: 0.01883 seconds
Time After: 0.01928 seconds
Time Before: 0.02194 seconds
Time After: 0.02312 seconds
Time Before: 0.01814 seconds
Time After: 0.02338 seconds
Time Taken: 0.00523 seconds
Time Before: 0.03378 seconds
Time After: 0.03396 seconds
Time Before: 0.03904 seconds
Time After: 0.04027 seconds
End call of global.php: 0.042624950408936
Time Before: 0.04572 seconds
Time After: 0.04588 seconds
Time Before: 0.04830 seconds
Time After: 0.04975 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120204', badlocation = 1
Time Before: 0.06325 seconds
Time After: 0.06359 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.062330961227417 seconds with 9 queries, spending 0.0083053112030029 doing MySQL queries and 0.054025650024414 doing PHP things.
