Time Before: 0.01627 seconds
Time After: 0.02037 seconds
Time Taken: 0.00410 seconds
Time Before: 0.02045 seconds
Time After: 0.02095 seconds
Time Before: 0.02127 seconds
Time After: 0.02143 seconds
Time Before: 0.02230 seconds
Time After: 0.02460 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02149 seconds
Time After: 0.02873 seconds
Time Taken: 0.00725 seconds
Time Before: 0.03350 seconds
Time After: 0.03400 seconds
Time Before: 0.03655 seconds
Time After: 0.03776 seconds
Time Before: 0.03274 seconds
Time After: 0.03796 seconds
Time Taken: 0.00521 seconds
Time Before: 0.06157 seconds
Time After: 0.06175 seconds
Time Before: 0.07049 seconds
Time After: 0.07178 seconds
End call of global.php: 0.074669122695923
Time Before: 0.07883 seconds
Time After: 0.07904 seconds
Time Before: 0.08153 seconds
Time After: 0.08301 seconds
SET lastactivity = 1776686064, location = '/forums/private.php?do=newpm&explain=1&u=120228', badlocation = 1
Time Before: 0.10275 seconds
Time After: 0.10309 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.10175204277039 seconds with 9 queries, spending 0.0081803798675537 doing MySQL queries and 0.093571662902832 doing PHP things.
