Time Before: 0.00135 seconds
Time After: 0.00196 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00202 seconds
Time After: 0.00255 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00278 seconds
Time After: 0.00295 seconds
Time Before: 0.00382 seconds
Time After: 0.00620 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00304 seconds
Time After: 0.01182 seconds
Time Taken: 0.00878 seconds
Time Before: 0.01468 seconds
Time After: 0.01508 seconds
Time Before: 0.01836 seconds
Time After: 0.02020 seconds
Time Taken: 0.00185 seconds
Time Before: 0.01388 seconds
Time After: 0.02050 seconds
Time Taken: 0.00662 seconds
Time Before: 0.02614 seconds
Time After: 0.02633 seconds
Time Before: 0.02835 seconds
Time After: 0.02956 seconds
End call of global.php: 0.031158924102783
Time Before: 0.03245 seconds
Time After: 0.03262 seconds
Time Before: 0.03461 seconds
Time After: 0.03609 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120338', badlocation = 1
Time Before: 0.05076 seconds
Time After: 0.05103 seconds
Page generated in 0.049843788146973 seconds with 9 queries, spending 0.0086581707000732 doing MySQL queries and 0.041185617446899 doing PHP things.
