Time Before: 0.00177 seconds
Time After: 0.00232 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00239 seconds
Time After: 0.00294 seconds
Time Before: 0.00327 seconds
Time After: 0.00349 seconds
Time Before: 0.00419 seconds
Time After: 0.00678 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00356 seconds
Time After: 0.01147 seconds
Time Taken: 0.00790 seconds
Time Before: 0.01373 seconds
Time After: 0.01420 seconds
Time Before: 0.01676 seconds
Time After: 0.01800 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01282 seconds
Time After: 0.01819 seconds
Time Taken: 0.00537 seconds
Memory After: 2,261.703 KB
Time Before: 0.02381 seconds
Time After: 0.02404 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02606 seconds
Time After: 0.02733 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03150 seconds
Time After: 0.03183 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03481 seconds
Time After: 0.03625 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120346', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04948 seconds
Time After: 0.04981 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
