Time Before: 0.01812 seconds
Time After: 0.02894 seconds
Time Taken: 0.01083 seconds
Time Before: 0.02906 seconds
Time After: 0.02955 seconds
Time Before: 0.02980 seconds
Time After: 0.02994 seconds
Time Before: 0.03094 seconds
Time After: 0.03334 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03001 seconds
Time After: 0.03817 seconds
Time Taken: 0.00816 seconds
Time Before: 0.04805 seconds
Time After: 0.04855 seconds
Time Before: 0.05240 seconds
Time After: 0.05364 seconds
Time Before: 0.04719 seconds
Time After: 0.05389 seconds
Time Taken: 0.00670 seconds
Time Before: 0.09069 seconds
Time After: 0.09087 seconds
Time Before: 0.10706 seconds
Time After: 0.10879 seconds
Time Taken: 0.00172 seconds
End call of global.php: 0.11105704307556
Time Before: 0.11885 seconds
Time After: 0.11908 seconds
Time Before: 0.12169 seconds
Time After: 0.12321 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=12041'
Time Before: 0.14299 seconds
Time After: 0.14348 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.14187788963318 seconds with 9 queries, spending 0.0089266300201416 doing MySQL queries and 0.13295125961304 doing PHP things.
