Time Before: 0.00841 seconds
Time After: 0.01345 seconds
Time Taken: 0.00504 seconds
Time Before: 0.01355 seconds
Time After: 0.01407 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01429 seconds
Time After: 0.01445 seconds
Time Before: 0.01517 seconds
Time After: 0.01748 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01451 seconds
Time After: 0.02180 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02916 seconds
Time After: 0.02960 seconds
Time Before: 0.03217 seconds
Time After: 0.03344 seconds
Time Before: 0.02846 seconds
Time After: 0.03364 seconds
Time Taken: 0.00517 seconds
Time Before: 0.05771 seconds
Time After: 0.05787 seconds
Time Before: 0.07253 seconds
Time After: 0.07380 seconds
End call of global.php: 0.075752019882202
Time Before: 0.08316 seconds
Time After: 0.08333 seconds
Time Before: 0.08567 seconds
Time After: 0.08716 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120414'
Time Before: 0.10512 seconds
Time After: 0.10545 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.10411500930786 seconds with 9 queries, spending 0.0081441402435303 doing MySQL queries and 0.095970869064331 doing PHP things.
