Time Before: 0.00195 seconds
Time After: 0.00254 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00264 seconds
Time After: 0.00340 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00367 seconds
Time After: 0.00380 seconds
Time Before: 0.00448 seconds
Time After: 0.00738 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00384 seconds
Time After: 0.01079 seconds
Time Taken: 0.00694 seconds
Time Before: 0.01271 seconds
Time After: 0.01314 seconds
Time Before: 0.01554 seconds
Time After: 0.01734 seconds
Time Taken: 0.00180 seconds
Time Before: 0.01210 seconds
Time After: 0.01751 seconds
Time Taken: 0.00541 seconds
Time Before: 0.02294 seconds
Time After: 0.02309 seconds
Time Before: 0.02519 seconds
Time After: 0.02653 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.029074192047119
Time Before: 0.03044 seconds
Time After: 0.03059 seconds
Time Before: 0.03325 seconds
Time After: 0.03505 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120419'
Time Before: 0.04993 seconds
Time After: 0.05025 seconds
Page generated in 0.048979997634888 seconds with 9 queries, spending 0.0097963809967041 doing MySQL queries and 0.039183616638184 doing PHP things.
