Time Before: 0.01084 seconds
Time After: 0.01408 seconds
Time Taken: 0.00324 seconds
Time Before: 0.01415 seconds
Time After: 0.01467 seconds
Time Before: 0.01494 seconds
Time After: 0.01506 seconds
Time Before: 0.01581 seconds
Time After: 0.01812 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01513 seconds
Time After: 0.02229 seconds
Time Taken: 0.00716 seconds
Time Before: 0.02802 seconds
Time After: 0.02848 seconds
Time Before: 0.03100 seconds
Time After: 0.03226 seconds
Time Before: 0.02728 seconds
Time After: 0.03249 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05298 seconds
Time After: 0.05313 seconds
Time Before: 0.06322 seconds
Time After: 0.06448 seconds
Time Before: 0.07284 seconds
Time After: 0.07320 seconds
Time Before: 0.07542 seconds
Time After: 0.07733 seconds
Time Taken: 0.00190 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120531' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.09320 seconds
Time After: 0.09345 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
