Time Before: 0.00218 seconds
Time After: 0.00277 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00288 seconds
Time After: 0.00342 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00396 seconds
Time After: 0.00449 seconds
Time Before: 0.00534 seconds
Time After: 0.00831 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00470 seconds
Time After: 0.01167 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01437 seconds
Time After: 0.01474 seconds
Time Before: 0.01723 seconds
Time After: 0.01860 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01380 seconds
Time After: 0.01877 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02351 seconds
Time After: 0.02366 seconds
Time Before: 0.02560 seconds
Time After: 0.02701 seconds
End call of global.php: 0.028713941574097
Time Before: 0.03006 seconds
Time After: 0.03040 seconds
Time Before: 0.03287 seconds
Time After: 0.03431 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120565', badlocation = 1
Time Before: 0.04668 seconds
Time After: 0.04693 seconds
Page generated in 0.045734882354736 seconds with 9 queries, spending 0.0093555450439453 doing MySQL queries and 0.036379337310791 doing PHP things.
