Time Before: 0.01058 seconds
Time After: 0.01712 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01720 seconds
Time After: 0.01769 seconds
Time Before: 0.01791 seconds
Time After: 0.01803 seconds
Time Before: 0.01875 seconds
Time After: 0.02137 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01810 seconds
Time After: 0.02536 seconds
Time Taken: 0.00726 seconds
Time Before: 0.03164 seconds
Time After: 0.03184 seconds
Time Before: 0.03453 seconds
Time After: 0.03572 seconds
Time Before: 0.03092 seconds
Time After: 0.03592 seconds
Time Taken: 0.00500 seconds
Time Before: 0.06107 seconds
Time After: 0.06121 seconds
Time Before: 0.43275 seconds
Time After: 0.43421 seconds
Time Before: 0.44066 seconds
Time After: 0.44086 seconds
Time Before: 0.44331 seconds
Time After: 0.44475 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120569', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.46159 seconds
Time After: 0.46186 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
