Time Before: 0.00202 seconds
Time After: 0.00311 seconds
Time Taken: 0.00109 seconds
Time Before: 0.00321 seconds
Time After: 0.00384 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00405 seconds
Time After: 0.00424 seconds
Time Before: 0.00511 seconds
Time After: 0.00747 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00429 seconds
Time After: 0.01090 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01262 seconds
Time After: 0.01300 seconds
Time Before: 0.01550 seconds
Time After: 0.01665 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01209 seconds
Time After: 0.01683 seconds
Time Taken: 0.00473 seconds
Memory After: 2,261.820 KB
Time Before: 0.02191 seconds
Time After: 0.02211 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02398 seconds
Time After: 0.02521 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.02683687210083
Time Before: 0.02795 seconds
Time After: 0.02808 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03009 seconds
Time After: 0.03156 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788955125, location = '/forums/private.php?do=newpm&explain=1&u=120578', badlocation = 1
Time Before: 0.04381 seconds
Time After: 0.04419 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.042927980422974 seconds with 9 queries, spending 0.0081188678741455 doing MySQL queries and 0.034809112548828 doing PHP things.
