Time Before: 0.01530 seconds
Time After: 0.02242 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02252 seconds
Time After: 0.02295 seconds
Time Before: 0.02323 seconds
Time After: 0.02339 seconds
Time Before: 0.02418 seconds
Time After: 0.02728 seconds
Time Taken: 0.00311 seconds
Time Before: 0.02345 seconds
Time After: 0.03204 seconds
Time Taken: 0.00858 seconds
Time Before: 0.04149 seconds
Time After: 0.04198 seconds
Time Before: 0.04377 seconds
Time After: 0.04498 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04059 seconds
Time After: 0.04520 seconds
Time Taken: 0.00461 seconds
Memory After: 2,261.703 KB
Time Before: 0.06775 seconds
Time After: 0.06792 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08804 seconds
Time After: 0.08927 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10074 seconds
Time After: 0.10094 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10386 seconds
Time After: 0.10530 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120599', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.12137 seconds
Time After: 0.12164 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
