Time Before: 0.00147 seconds
Time After: 0.00208 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00216 seconds
Time After: 0.00263 seconds
Time Before: 0.00288 seconds
Time After: 0.00305 seconds
Time Before: 0.00376 seconds
Time After: 0.00624 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00309 seconds
Time After: 0.00960 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01154 seconds
Time After: 0.01196 seconds
Time Before: 0.01500 seconds
Time After: 0.01623 seconds
Time Before: 0.01090 seconds
Time After: 0.01640 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02141 seconds
Time After: 0.02157 seconds
Time Before: 0.02372 seconds
Time After: 0.02492 seconds
Time Before: 0.02798 seconds
Time After: 0.02819 seconds
Time Before: 0.03022 seconds
Time After: 0.03162 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12060' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04381 seconds
Time After: 0.04417 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
