Time Before: 0.02538 seconds
Time After: 0.03310 seconds
Time Taken: 0.00772 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03317 seconds
Time After: 0.03356 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03374 seconds
Time After: 0.03382 seconds
Time Taken: 0.00009 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03444 seconds
Time After: 0.03733 seconds
Time Taken: 0.00289 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03387 seconds
Time After: 0.04147 seconds
Time Taken: 0.00759 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04823 seconds
Time After: 0.04852 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05032 seconds
Time After: 0.05145 seconds
Time Taken: 0.00112 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04769 seconds
Time After: 0.05166 seconds
Time Taken: 0.00397 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.08078 seconds
Time After: 0.08089 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.13368 seconds
Time After: 0.13520 seconds
Time Taken: 0.00151 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
Time Before: 0.16395 seconds
Time After: 0.16417 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.16933 seconds
Time After: 0.17086 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=120726', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.19679 seconds
Time After: 0.19697 seconds
Memory Before: 5,997.781 KB
Memory After: 5,998.008 KB
