Time Before: 0.02506 seconds
Time After: 0.03493 seconds
Time Taken: 0.00987 seconds
Time Before: 0.03503 seconds
Time After: 0.03550 seconds
Time Before: 0.03573 seconds
Time After: 0.03588 seconds
Time Before: 0.03658 seconds
Time After: 0.03919 seconds
Time Taken: 0.00261 seconds
Time Before: 0.03593 seconds
Time After: 0.04330 seconds
Time Taken: 0.00736 seconds
Time Before: 0.05116 seconds
Time After: 0.05148 seconds
Time Before: 0.05284 seconds
Time After: 0.05406 seconds
Time Before: 0.05051 seconds
Time After: 0.05426 seconds
Time Taken: 0.00375 seconds
Time Before: 0.08513 seconds
Time After: 0.08529 seconds
Time Before: 0.34473 seconds
Time After: 0.34619 seconds
End call of global.php: 0.3486340045929
Time Before: 0.35383 seconds
Time After: 0.35397 seconds
Time Before: 0.35611 seconds
Time After: 0.35757 seconds
SET lastactivity = 1776651617, location = '/forums/private.php?do=newpm&explain=1&u=120729', badlocation = 1
Time Before: 0.37689 seconds
Time After: 0.37716 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.37588810920715 seconds with 9 queries, spending 0.0082650184631348 doing MySQL queries and 0.36762309074402 doing PHP things.
