Time Before: 0.00219 seconds
Time After: 0.00306 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00316 seconds
Time After: 0.00362 seconds
Time Before: 0.00385 seconds
Time After: 0.00404 seconds
Time Before: 0.00481 seconds
Time After: 0.00692 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00410 seconds
Time After: 0.01036 seconds
Time Taken: 0.00626 seconds
Time Before: 0.01297 seconds
Time After: 0.01337 seconds
Time Before: 0.01643 seconds
Time After: 0.01764 seconds
Time Before: 0.01238 seconds
Time After: 0.01791 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02546 seconds
Time After: 0.02560 seconds
Time Before: 0.02876 seconds
Time After: 0.03001 seconds
End call of global.php: 0.032043933868408
Time Before: 0.03388 seconds
Time After: 0.03402 seconds
Time Before: 0.03607 seconds
Time After: 0.03751 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120785'
Time Before: 0.05492 seconds
Time After: 0.05565 seconds
Time Taken: 0.00073 seconds
Page generated in 0.053705930709839 seconds with 9 queries, spending 0.0080738067626953 doing MySQL queries and 0.045632123947144 doing PHP things.
