Time Before: 0.00471 seconds
Time After: 0.00658 seconds
Time Taken: 0.00187 seconds
Time Before: 0.00667 seconds
Time After: 0.00708 seconds
Time Before: 0.00733 seconds
Time After: 0.00744 seconds
Time Before: 0.00820 seconds
Time After: 0.01032 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00750 seconds
Time After: 0.01525 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01747 seconds
Time After: 0.01789 seconds
Time Before: 0.02077 seconds
Time After: 0.02231 seconds
Time Taken: 0.00154 seconds
Time Before: 0.01686 seconds
Time After: 0.02259 seconds
Time Taken: 0.00572 seconds
Time Before: 0.03145 seconds
Time After: 0.03162 seconds
Time Before: 0.03658 seconds
Time After: 0.03782 seconds
End call of global.php: 0.040239095687866
Time Before: 0.04322 seconds
Time After: 0.04338 seconds
Time Before: 0.04588 seconds
Time After: 0.04734 seconds
SET lastactivity = 1788932090, location = '/forums/private.php?do=newpm&explain=1&u=120791'
Time Before: 0.06150 seconds
Time After: 0.06175 seconds
Page generated in 0.060281991958618 seconds with 9 queries, spending 0.0079021453857422 doing MySQL queries and 0.052379846572876 doing PHP things.
