Time Before: 0.00758 seconds
Time After: 0.01052 seconds
Time Taken: 0.00294 seconds
Time Before: 0.01062 seconds
Time After: 0.01120 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01148 seconds
Time After: 0.01162 seconds
Time Before: 0.01234 seconds
Time After: 0.01524 seconds
Time Taken: 0.00291 seconds
Time Before: 0.01168 seconds
Time After: 0.01976 seconds
Time Taken: 0.00807 seconds
Time Before: 0.02515 seconds
Time After: 0.02555 seconds
Time Before: 0.02804 seconds
Time After: 0.02934 seconds
Time Before: 0.02444 seconds
Time After: 0.02958 seconds
Time Taken: 0.00514 seconds
Time Before: 0.04247 seconds
Time After: 0.04271 seconds
Time Before: 0.05119 seconds
Time After: 0.05248 seconds
Time Before: 0.05912 seconds
Time After: 0.05944 seconds
Time Before: 0.06212 seconds
Time After: 0.06359 seconds
UPDATE session SET lastactivity = 1788884295, location = '/forums/private.php?do=newpm&explain=1&u=120829' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.07922 seconds
Time After: 0.07962 seconds
