Time Before: 0.00149 seconds
Time After: 0.00204 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00210 seconds
Time After: 0.00255 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00408 seconds
Time After: 0.00697 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00296 seconds
Time After: 0.01213 seconds
Time Taken: 0.00916 seconds
Time Before: 0.01443 seconds
Time After: 0.01480 seconds
Time Before: 0.01721 seconds
Time After: 0.01839 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01375 seconds
Time After: 0.01865 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02537 seconds
Time After: 0.02551 seconds
Time Before: 0.02732 seconds
Time After: 0.02854 seconds
End call of global.php: 0.030259132385254
Time Before: 0.03152 seconds
Time After: 0.03169 seconds
Time Before: 0.03370 seconds
Time After: 0.03520 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=120830', badlocation = 1
Time Before: 0.04797 seconds
Time After: 0.04884 seconds
Time Taken: 0.00088 seconds
Page generated in 0.047018051147461 seconds with 9 queries, spending 0.0089333057403564 doing MySQL queries and 0.038084745407104 doing PHP things.
