Time Before: 0.00153 seconds
Time After: 0.00212 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00219 seconds
Time After: 0.00272 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00303 seconds
Time After: 0.00320 seconds
Time Before: 0.00411 seconds
Time After: 0.00703 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00327 seconds
Time After: 0.01269 seconds
Time Taken: 0.00941 seconds
Time Before: 0.01457 seconds
Time After: 0.01483 seconds
Time Before: 0.01707 seconds
Time After: 0.01832 seconds
Time Before: 0.01400 seconds
Time After: 0.01849 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02446 seconds
Time After: 0.02469 seconds
Time Before: 0.02660 seconds
Time After: 0.02815 seconds
Time Taken: 0.00156 seconds
Time Before: 0.03093 seconds
Time After: 0.03108 seconds
Time Before: 0.03303 seconds
Time After: 0.03451 seconds
UPDATE session SET lastactivity = 1772325507, location = '/forums/private.php?do=newpm&explain=1&u=120869', badlocation = 1 WHERE sessionhash = '698797e133468fae88ff263759a79e28'
Time Before: 0.05087 seconds
Time After: 0.05115 seconds
