Time Before: 0.02102 seconds
Time After: 0.02448 seconds
Time Taken: 0.00345 seconds
Time Before: 0.02456 seconds
Time After: 0.02503 seconds
Time Before: 0.02528 seconds
Time After: 0.02544 seconds
Time Before: 0.02621 seconds
Time After: 0.02896 seconds
Time Taken: 0.00275 seconds
Time Before: 0.02550 seconds
Time After: 0.03332 seconds
Time Taken: 0.00781 seconds
Time Before: 0.04110 seconds
Time After: 0.04136 seconds
Time Before: 0.04456 seconds
Time After: 0.04585 seconds
Time Before: 0.04038 seconds
Time After: 0.04604 seconds
Time Taken: 0.00566 seconds
Time Before: 0.07310 seconds
Time After: 0.07326 seconds
Time Before: 0.08793 seconds
Time After: 0.08922 seconds
End call of global.php: 0.091112852096558
Time Before: 0.09622 seconds
Time After: 0.09640 seconds
Time Before: 0.09900 seconds
Time After: 0.10056 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1783241630, location = '/forums/private.php?do=newpm&explain=1&u=12088', badlocation = 1
Time Before: 0.11793 seconds
Time After: 0.11836 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.11683487892151 seconds with 9 queries, spending 0.008540153503418 doing MySQL queries and 0.10829472541809 doing PHP things.
