Time Before: 0.00142 seconds
Time After: 0.00200 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00207 seconds
Time After: 0.00252 seconds
Time Before: 0.00271 seconds
Time After: 0.00286 seconds
Time Before: 0.00354 seconds
Time After: 0.00622 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00290 seconds
Time After: 0.00966 seconds
Time Taken: 0.00676 seconds
Time Before: 0.01156 seconds
Time After: 0.01201 seconds
Time Before: 0.01468 seconds
Time After: 0.01594 seconds
Time Before: 0.01089 seconds
Time After: 0.01614 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02279 seconds
Time After: 0.02324 seconds
Time Before: 0.02514 seconds
Time After: 0.02641 seconds
End call of global.php: 0.028158903121948
Time Before: 0.02945 seconds
Time After: 0.02965 seconds
Time Before: 0.03174 seconds
Time After: 0.03317 seconds
SET lastactivity = 1783067294, location = '/forums/private.php?do=newpm&explain=1&u=121003'
Time Before: 0.04556 seconds
Time After: 0.04618 seconds
Time Taken: 0.00062 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.044664859771729 seconds with 9 queries, spending 0.0089700222015381 doing MySQL queries and 0.03569483757019 doing PHP things.
