Time Before: 0.00149 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00243 seconds
Time Before: 0.00263 seconds
Time After: 0.00275 seconds
Time Before: 0.00346 seconds
Time After: 0.00558 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00279 seconds
Time After: 0.00914 seconds
Time Taken: 0.00635 seconds
Time Before: 0.01103 seconds
Time After: 0.01143 seconds
Time Before: 0.01458 seconds
Time After: 0.01575 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01039 seconds
Time After: 0.01595 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02117 seconds
Time After: 0.02132 seconds
Time Before: 0.02340 seconds
Time After: 0.02465 seconds
End call of global.php: 0.027209997177124
Time Before: 0.02867 seconds
Time After: 0.02883 seconds
Time Before: 0.03169 seconds
Time After: 0.03320 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1785292299, location = '/forums/private.php?do=newpm&explain=1&u=121143'
Time Before: 0.04835 seconds
Time After: 0.04872 seconds
Page generated in 0.047106027603149 seconds with 9 queries, spending 0.0076391696929932 doing MySQL queries and 0.039466857910156 doing PHP things.
